Re: Wire Harness for f150
on the 05 motor you will have two small connectors on the harness side and one that is plugged on the engine side. remove the plugged square four pin and hook one side of the harness connector to it. use the plug from the engine side to cap off the connector that is not used on the harness side. its all in the 05 tech and the 05 rigging guide.<br />if your going to rig it yourself ya need the correct manuals.
