wire identification ?(on harness Indmar / Volvo spec)
capeshore
These are coming off the engine wiring harness. 5.7 indmar spec to exact fit for volvo transom sx-c1.All has been easy so far.
black,yellow with black line...then tan with black line,black wire.I don't know what they are or go too? Thanks fr the help, I'm in the yard abd no access on sat. to get a manual etc.indmar wires.jpg
capeshore
Re: wire identification ?(on harness Indmar / Volvo spec)
So did some extensive reading here and online. Also some more testing showed me the boot wires are ignition. Still don't know where they go but grounding them the engine will now turn over with key. But they must have a home and not just a ground lug as they are small eyelets.
Bigger question (and from reading here) the rectangle plug is for the trim tilt ? The harness coming out of the (sx-c1 volvo pump) is not the same? I read about a adapter harness here? No longer using something or other? Anybody know where any of these will go now that I have an idea of what they all are? Thanks!
