Wire size question
GaryAK
I picked up a loud hailer...the leads are 24 awg. I'll have to splice in about a 5 ft. section to reach my radio. I have some 20 awg. Will that work or do I need to buy some 24 awg for the splice?
Trooper583
Re: Wire size question
You can never go wrong splicing in wire that is larger than is required to run the device or that is already in place. If you splice a smaller wire in you will increase the resistance of the circuit causing heat and less efficient operation.
