rusty bolts
- Joined
- Aug 20, 2004
- 148
hello/ volt meter was replaced with a hour meter / how would i wire a new volt meter gauge on a 1987 omc 460 grady white thanks to all on this fourm it great jd
Huh!!! A voltage meter doesn't draw but a few milliamps of current.I do not recommend a volt meter that far from the battery ---- loss of voltage due to wire resistance --- however, if you run nice sized wires #10 up there the meter draws little current so the voltage should be real close.
Either way it will be close enough to let you know if the charging system is working.
There should be a positive wire going to the instrument cluster and a negative --- hook up there --- if there is a ammeter ---> hook to the feed side not the load side
OFM
He was talking about a voltmeter not an ammeter. Nobody uses an ammeter anymore. Maybe in the 70s but not anymore.I do not recommend a volt meter...
