Wires on control box under tention adjust, 1986 Johnson 85HP
ToBold
I have an 1986 85HP Johnson
On the control box there are two wires connected to a rubber plug that can be pulled off of the control box. The plug is just under the tention control. The plug has two wires coming out of it and a third wire that is pluged off by the factory, not used. I assumed it was for the kill switch, but with the wires not running to anything or unplugged from the connector the motor will start.
What are the wires and where do they go.
Thanks;
WillyBWright
Re: Wires on control box under tention adjust, 1986 Johnson 85HP
They would feed gauges. I'm betting you have none save maybe a speedo and gas gauge that go on with the light switch?
