Wiring 1997 75 hp 2 stroke 3 cyl CDM
Dennis G
1997 75 HP merc. 3 cyl. Oil injected, tilt 2 stroke. Finally solved the no spark problem. I found (after 2 months) the two yellow wires from the stator to the regulator/rectifier fried and shorted together. After separating the two and shrink wrapping then up, all is well with my motor. Only thing is, I have two wires at the bottom of the motor that ar hanging loose. one tan (w/ female connector) and one dark brown with a white stipe (w/ male connector. The tan one runs up to the control box and is disconnected. Is this the tach wire? Does this tan wire connect to the dark brown w/ white stripe at the motor? I don't know if I disconnected the two or if they were always disconnected. My new manual does not show either of the two wires. HELP!!! Thanks in advance for replies. Dennis G.
WillyBWright
Re: Wiring 1997 75 hp 2 stroke 3 cyl CDM
Those are gauge wires. The brown with the white stripe would be the sender wire for a trim gauge. The tan one is intended for a temperature sender, but you could use it for any sender. If the gauges ain't there, they do nothing.<br /><br />Check your battery connections. The yellows may have overheated from corrosion at those bullet connections. But believe it or not they can do that from loose and/or corroded battery connections. Crank on those wingnuts with a pliers. I prefer to replace them with stainless locknuts. That way you have to use a wrench. Wingnuts are the number one cause of charging system failures. 99% of boaters think that finger-tight is enough. Not!
