Wiring 20ft Trailer, not familiar with materials I need
bhollehday
I need to run all new wires on my 20ft boat trailer. I cant find any wirings kits and suppose Im supposed to buy the 7 pin connector (or 5 pin flat if you prefer) and then buy some marine grade wire spool to connect and run down the rails of the trailer? What kind of connectors do you use? I wish I could just buy a 7pin plug with 30ft wires to minimize connections..
Grub54891
You can buy the wire in bulk at most hardware store, or auto parts stores. The connectors we use are the shrink tube type, crimp the connector, heat it up and it seals the connections. When I did my pontoon trailer, I bought led light kit, came with enough wire to run all the way, plus extra. 20 foot trailer.
Grub54891
The wire comes pre-made, 4-5 wires all together. I think 16 gauge, but not positive. Led's draw little power.
Woodonglass
With a 20% off coupon you can get a FULL LED Trailer light kit (Including lights, wiring and connectors) for about $35 bucks. I recommend shrink wrapping all connections. Key to wiring any trailer is to make certain you have a good dependable ground.
tanman34
Don't know why they cant offer these kits with the wires made into the lights since those are the connections that get dunked every time.
Grub54891
Because they want to sell more lights. When wired correctly, and checked every season, they last for years, I've had them last 10 years.
rmnwood
I've rewired several boat trailers and I always use 16 ga marine tinned wire, solder the connections and use marine grade adhesive shrink tubing to cover the soldered connections. I pigtail the ground wire, with one connection on the trailer tongue and then to the left light and pigtail that ground to the right light. I also always put all of the wiring in a 3/8" split loom to keep the UV from deteriorating the wires.
