Hello ,
i`m wiring up old 14` Lowe Boat w 15hp - Need advise on how to layout and wire up Boat . Battery will sit mid ship under the centre row Bench . with a Voltage Meter and RPM/Hour run Meter beside it . Also will mount a small electrical panel 6 switches w fuses and a dc cigarette lighter mounted on the side of the Bench about 2 ft away . I have a special Cable I order , which supposedly runs from my Honda Motor & has a rectifier / regulator to keep the Battery charged , but not sure where it should wire into . The 6 switches I would dedicate to the bilge pump/Nav.Lights / Cigarette Receptical / Fish Finder/ Voltage Gauge/ RPM Gauge. Does this sound normal ? Where is a good place to ground the Battery to and how long or what size cable do you recommend ? The rest of the wiring, what size should I use . Where should I wire in the Cable from Motor/rectifier/regulator ? and do I put a main red shut-off switch to disconnect the whole system if needed ? Whats your take on solar panels & chargers ? Is it worth it or is an on board charging system better. Any information /diagram layout would be greatly appreciated !
THANKS in advance.
THANKS in advance.
