Hi All!!!
I had a crazy idea of wiring in a third brake light. I have a 1988 Bayliner Capri 1950 CX, It is on the EZLoad single axle trailer it came with. I replaced the brake lights with a LED kit but had a crazy idea of buying one of the red LED side marker lights and wiring it into the brake light electrical. Then have it on a little 6 ft cord and attach it to the rear of the boat while trailering, like to the towrope cleat or something. Then when putting the boat in the lake i can take it off and attach it to one of the side bunks or something.
How would you wire this? If i used the wire from one side of the system it would work for braking but wouldn't it flash if i used that sides turn signal?
Thanks for all your input
Rod
Rod
