Wiring a "Red Plug" to a "Black Plug" Motor
toolmandancer
Pontoon has a Red Plug harness and the motor is '76 35hp Evin. with a Black Plug. Does anyone make an adapter? I really don't want to run a complete harness. The motor has a harness, but it's not long enough. Anyone know the simplest way to fix this without changing the boat side harness? Thanks, Bill.
tashasdaddy
Re: Wiring a "Red Plug" to a "Black Plug" Motor
new one on me, i thought all the plugs in '76 were red. easier to change the motor harness. sounds like someone replace the harness with an 1969 harness.
Rudi2
Had kind of the same problem myself, I picked up a '78 Starcraft at an estate sale last fall with the intention of installing a '95 'Rude I have from my last boat. The Starcraft has a black plug and the 'Rude is a red plug motor, after checking around I was told that OMC changed to the red plug on the '79-'80 models. I was able to pick a red boat-side harness thinking to swap it out, that'll have to wait till warmer weather now. As as far as your situation, I would think changing the harness would make the cleanest installation, if you didn't want to go to that trouble you might be able to just swap out end plugs. Get a shop manual or do an internet search for a wiring diagram.
