Wiring a Seachoice 12521
RavenWatcher
Thanks to all who will share some wisdom!
I am doing some re-wiring on my boat and I want to run everything through a fused switch panel. I have purchased a Seachoice 12521 - 6 gang fused fusebar. For the life of me I cannot figure the wiring diagram to ground the panel. A quick search on seachoice.com for seachoice12521 will lead you to the page where the wiring diagram I have is posted. I understand the common "hot" on the bottom left. Where is the ground?
Also, how do the individual devices (running lights, anchor light, depthfinder, etc.) connect to the positive lead? Do I have to learn how to solder them in?
Thanks again,
Raven
MH Hawker
Re: Wiring a Seachoice 12521
I took a quick look at the panel, and it doesn't seam to have lights on it so it wont be grounded it just breaks the 12 volt hot wire out to each device. And the hook ups should be spade connections.
All of the grounds should be connected to a ground buss and wont go through the switches.
Don S
Post a picture of the back of your panel.
