retiredfornow
- Joined
- May 9, 2011
- 355
A 8 to 18 volt gauge was given to me, and I thought I'd drill a hole and mount it in my CC, since I don't have a volt gauge and I would like to see if the motor is charging the battery while running. On the back are 3 screw studs and one spade connection. The spade is for the light bulb. One screw is marked "S" and is capped off with a plastic sleeve. The other 2 are marked "I" and "G". I assume the "G" is ground and the "I" is ignition? So I find the hot wire at the ignition switch and hook it up there? Electricity is not my forte. Thanks for any help.
