Re: wiring batteries
It is wise to kick up the capacity of the battery bank if you can. Often, the cost of doubling its size will more than doubling the useful life of the battery bank. The deeper you discharge a battery per cycle, the faster it decays. Some common bats have a life of 20-years if you dont discharge them more than 10%, but only 300 to 400 cycles if taken down to 50% discharge. Most recreational boats arent designed for the space and weight distribution of a bunch of batteries, but then for occasional use a bunch of bats is overkill.<br /><br />When I read high amp I think starting battery. If you have starting bats in there for your tm, they will give up the ghost very quickly, and that leads to a huge strain on any other bats you added in the bank. This is why it is recommended you use bats of the same age, size, manf, type, model number, etc when connecting them in series. Its a good idea but not as important if connected in parallel. In most cases, when connecting multiple bats folks will be using NEW batteries or bats purchased within a few months of each other. Cant stress enough how important it is to use identical bats in a bank when in series.
