Can I use the aluminum boat hull for ground, or should I run a separate wire for thr ground?
S SOG3 Petty Officer 3rd Class Joined Aug 24, 2015 Messages 78 Feb 6, 2023 #1 Can I use the aluminum boat hull for ground, or should I run a separate wire for thr ground?
G Grandpa348 Recruit Joined Feb 6, 2023 Messages 5 Feb 6, 2023 #2 SOG3 said: Can I use the aluminum boat hull for ground, or should I run a separate wire for thr ground? Click to expand... Its best to use a ground wire. Electrolysis is a nasty problem.
S SOG3 Petty Officer 3rd Class Joined Aug 24, 2015 Messages 78 Feb 6, 2023 #3 Thanks Grandpa, I was pretty sure that was the answer I was looking for!
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,230 Feb 6, 2023 #4 Never use the hull as a ground
