Wiring diagram for old Minnkota 99 TM needed
seanymph85
The old Minnkota 99 trolling motor that was on this boat when I got it has a forward/reverse switch that goes forward when switched to reverse and vice versa. I tried switching a couple of wires on the forward reverse switch but it didn't help.
Does anyone have any idea where I can locate a complete wiring diagram for this old unit?
Silvertip
If this is a rocker or toggle type switch, simply remove the switch and turn the 180 degrees. Presto -- FWD is now FWD and REV is REV.
seanymph85
Yes I finally figured that might work prior to seeing this tip and it worked! I unclipped the back part of the switch from the front reconnected the wires per the diagram
Minnolta provided and it worked that way. Thanks for the time in making the suggestion!
