Wiring Diagram for Trim Sender Limit Switch
man-of-war
Hello all,<br />I had the mechanic install 2 trim sender limit switches thinking that he would install the wiring. What I have is on the dash is the gauge with 3 wires, 1) purple which goes to ignition key, 2) a grey wire that goes to the killswitch on the transom plate (this is the switch that cuts the engine for a fraction when changing gears) and 3) a black wire which I think is the ground. I used a 12 volt bulb to test the wire to the killswitch, it didn't glow as bright as a direct from the battery. There are 2 light blue wires joined together in a female booth and 1 purple with a female booth. NEED SOME HELP
Trent
Re: Wiring Diagram for Trim Sender Limit Switch
Make, model and year would help
man-of-war
it's a 1980 23ft wellcraft , with an alpha one outdrive year 86-88
man-of-war
can't aford the mechanic. NEED HELP
