Re: Wiring diagram?
LSUFan71,
The wiring of a boat is a very simple process.
The hardest process is feeding the wire thru the small orfice on the boat.
If the boat has some old wire already running thru, I would suggest you tie some string or rope to the end. You can use the string for a guide to pull your new wire thru. I also suggest you run all your wire to a fuse box, then run your battery wire (pos. & neg) to the fuse box..Remember red or black is hot and White or green should be negative. Are you running a 24volt or 12 volt troll motor system?
