Wiring Diagram
ABS7
Can anyone tell me where to find a wiring diagram, that shows the fuse block for a 1992 Play Craft Elite. I need the lighting diagram that shows the fuse and where the anchor light wiring runs to. Cant get the anchor light to come on. Also wont come on with the running lights. I tested the anchor light and it does work.
Thanks for your help.
5150abf
Re: Wiring Diagram
They are generally under the console but I don't think you will find a diagram of it, boats just aren't like that so you are going to have to follow wires and find it yourself, start at the switches and work back, fuse blocks are normally close to the switches.
Modern boat use breakers but don't know if they had them in 92
Silvertip
Re: Wiring Diagram
If the anchor light works and the NAV lights don't, the circuit is getting power because the same switch controls both. Since there are two nav lights (red on one side and green on the other), and both are out, that tells me either the hot (+12 volt line) or the ground line FEEDING the lights is broken or disconnected. And I'm sure you checked the bulbs --- not???????? After all they are up front where it is usually wet so corrosion may be at work up there.
2 Eagles
Re: Wiring Diagram
Silvertip is some what right. He must of miss read. If the NAV lights are working than you have power to the switch so the fuse is fine. Have you traced the Anchor light feed. On most pontoons there is a plug that connects & disconnects the anchor light. The plug is located around the frame bolts for the canopy so that you can take the conapy off. That plug maybe undone or corroded.
