Wiring dual batteries
leafnut7
Hi all, I was wonderin' if anyone knows of a website that has a wiring diagram for hooking up a dual battery system. Thanks in advance.
18rabbit
Re: Wiring dual batteries
Leafnut7 – there are several way to wire a two-bank battery system in your boat. You should probably start with a consideration of what you want the dual bat system for and then proceed from there. Charging is also a concern…on board alternator vs. recharging back at the barn, etc. What are your expectations for charging the system?<br /><br />Suggestion: Guest battery switch.
