further
- Joined
- Jun 18, 2009
- 1,031
First time wiring in my new to me Chaparral Sunesta. New kenwood h/u, kenwood amp, 4 kicker 6.5’s and 1-10” sub. Ran 4 gauge power from amp to breaker mounted near battery switch then to battery switch. Ran same gauge ground from amp to battery. Amp is a 5 channel so all 4 speakers and sub wired direct to amp. Patch cables between amp and head unit. I’m a bit confused on how to wire the rest...From the wiring harness on the new head unit and the factory harness. Assuming the blue and white p. cont wire from the head unit goes to the p. con terminal on the amp and that powers the h/u? What else do I connect between the head unit and the factory harness and amp? The h/u wiring harness has red, black and yellow wires along with a green and yellow for remotes and brown for mute. Does anyone have a wiring diagram for something similar?
TIA
TIA
