steve forsythe
- Joined
- Nov 7, 2001
- 245
I have an 1100 gph pump that fills my bait tank. It is hooked to a switch on my panel. I added another 1100 gph Rule aerator pump inside the bait tank and connected the pump with a splitter to the positive wire of the other pump so they both will turn on at the same time with the same switch. It works fine when you turn it on, but it cuts off and on the whole time. It will run for 30 seconds and then cut off for 20-40 seconds etc. Why????? Is there too much load on the switch?? Should i have conected the positive wire from the Rule directly to the switch and not spliced it into the other wire? Or should i put a switch in that can handle the 2 pumps? I dont know what kind of switches are in there but i do know that on another switch i have 3 or 4 things hooked directly to the switch. Could splicing into the positive feed make it cut out??? Any help or input would be great.
