nemo2011
- Joined
- Feb 15, 2011
- 157
My merc 1989 4.3 L I had it out for hull repair,when I reinstalled motor and hooked up all the wiring, It started fine,and everything gauges etc seem ok.
But I do have a tan wire with blue striping near where the wiring connector on the port side elbow is located and I have no idea where this wire gets connected to? and I cannot remember if it in fact was connected when motor was taken out.
Motor runs fine! I searched high and low in the vicinity of the wire end but could not find any possible place where the wire would connect to using it's maximum limits.
I'm thinking that the wire must be for something,
Wiring schematic points to heat sensor, oil reservoir ,(what's that)
heat gauge seems to work fine!
any idea's?
any idea's?
