Tanksmydog
- Joined
- Jul 8, 2008
- 41
Hey! I am having a couple issues with my light and horn that is most likely a wiring problem. I am rewiring the boat due to the crappy job someone else did before. I hook the pos and neg to the correct battery terminals and both work great, BUT when I hook the switch and then add the power wire(and neg too) it works when the switch is in the off position but when I switch it on it sparks and smokes as though I was jumping a wire across the battery. I need help quickly, I have been working on the boat all summer and would like to take the boat out at least once this year.
A little info on the boat...It is a 14 ft fiberglass Duo(closed bow)...It has a 50 hp it.
Also does anyone have a jackplate for sale or that can be easily made that will hold up for several years? Thank you for looking and for all the help in advance!
