SHickey
- Joined
- Apr 29, 2011
- 263
Hello and Happy Fathers Day,
I am working on a project, 1974 21' Mirrocraft that has a Mercruiser 140 3.0 motor with a MC-1 outdrive. This boat is in the process of being gutted out considering there are decking screws, red plastic tape, and different colored wires connected together for the same device. It is almost comical how this boat was maintained or fixed and it is no wonder most all of the electrical items; nav lights, instruments, blower, horn, wiper and bilge pump don't work.
I also discovered the forward wiring harness that plugs into the motor wiring harness do not have the same colored wires. This may be due to someone switching wiring harness at one time or another. This mismatch in wire colors compound the problem of trying to figure out what wire goes where when I hook up the ignition, instruments and the neut cut off switch.
At the motor end the female connector has 3 heavy wires; Red/White, Black and Red and 6 thin wires, Green, Brown, White, Purple, Orange and Yellow.
The forward wire bundle with the male connector has 3 heavy wires; Red, Orange, and Black and 6 thin wires White, Tan, Grey, Blue and two Purple wires.
It is very difficult for me to figure out what goes to what considering the actual wire path is hidden by the heavy rubber connector housing.
If anyone could help me figure out which colored wire goes to the different instruments (temp, Volt, pressure, Trim), ignition, and neu cut off connections that would be most helpful. I do not want to just hook things up and experiment if someone may have an old wiring diagram that may match this particular wiring harness I have on this old tin can.
As always, any help is most welcome!!
