I solder everything and anything. Just make sure you use a good grade marine tinned wire, and of the correct gauge for the load.
... and whatever you use - do not use any solid wire like the household stuff. Use only strand (and that goes for any AC wiring as well), even if you can't get the tinned wire. You'll just need to replace it sooner than later. Solid wire does not belong on a boat. It could negate an insurance claim if such a worse case scenario occurs.
Not that I was going to use the solid wire - but why is it a problem?
