Pbdy Jr
- Joined
- Apr 14, 2013
- 30
I have purchased a pertronix ignitor electronic ignition and a flamethrower coil. I was hooking this up but was unsure where these wires from my old coil should go.
SEE PHOTO(s)
the grey wire appears to go from the tachometer to the negative on the coil. should i put this back?
the instructions say that the coil gets the red wire to the IGNITOR and a wire to the ignition switch. My old coil had the purple/yellow wire here which comes from the solenoid not the ignition switch. should i run a wire from the ignition here? is is this what it was referring to?
Also it says to put the black wire of the IGNITOR to the negative coil terminal (no question here. lol)
SEE PHOTO(s)
