wiring problems
dan0001
hi i am new at this. i have a 1985 four winns 160 marquis that had a 120hp 2.5 and the motor was haft missing when got it i then bought a 1978 glasion with a 140 hp motor in so i took out the haft of the 120 hp and put in the 78 140 hp i was told to use my 85 wiring harness but the wiring code in the shop book is not the same color code on the wiring harness is there anyone no where i can find a diagraph for it thank you
Re: wiring problems
Ayuh,.... Are ya havin' trouble wirin' up the motor, or the motor to the boat,..??
You should use the motor harness that matches the distributer, 'n alternator yer usin'..??..
dan0001
Re: wiring problems
i haveing problem wiring up the motor from the harness that was on the old motor i dont rember the way the old motor was wired
Re: wiring problems
Ayuh,.... So which half of which motors ended up bein' used,..??
Answer my 2nd question in post 2....
Don S
Re: wiring problems
If the boat is an 85, use the engine wiring harness for the 85 engine. The 78 is not only a different color code, it probably had an ammeter instead of a voltmeter, which really changes the wiring.
Here are a bunch of wiring diagrams from that era. You are just going to have to pick out what you have. Lots of choices.
http://www.4shared.com/office/Fka6DUwp/Wire_Diag_120-140_3.html
dan0001
Re: wiring problems
i am useing the 1978 wole motor it is a 140 hpi/o with my 1985 wiring harness for my 85 motor
Don S
Re: wiring problems
If you are using the old wiring harness from the 85 on the 78 140, what exactly is the problem?
dan0001
Re: wiring problems
dont remember the diagraph on how it is wired the 78 motor has wiring code then the 85 motor but i have it hook up to when i turn on the key to start it it cranks but there is no spark to the coil it a new coil i have not change the points yet and i think i have the wiring back word
dan0001
Re: wiring problems
don s do u have a wiring diagram for a per alpha out drive i need to find out where the 4 wires go to out of the trans on a 1985 4 winns
Re: wiring problems
Ayuh,.... 2 are for the trim limit, 'n 2 are for the trim sender...
dan0001
Re: wiring problems
is there a wiring diagraph for to how to hook them up and where do they go to thanks
Don S
Re: wiring problems
You have everything there is diagram wise.
