Wiring Question - Trim pump unit seems bad 2007 5.7 SX-A
Tydog96
Part number 21945915. Pulled unit (mounted outside transom) based on initial troubleshooting. Lots of rust, some water, etc. Direct connect 12v power to the trim motor is unresponsive. WIRING: The power feed is two heavy gauge wires (Blue and Green). I get power there when tilt button rocker is activated, but still confused at UP versus DOWN. I thought maybe they are both POSITIVE coming from relays (up or down related) and thought the ground was maybe the cable wire to the bolts. But if I hook just a normal 12v tester, that is not what I see. How do I test. Confidence is high motor bad. I see power to the main wires, but don't how to proper test, and UP versus DOWN function. Again, looking to test wires to verify overall wiring works as designed. Thanks
