First a little background, I bought an unpowered 78 Whaler, with what appears to be original Evinrude top mount throttle/shift controls and a seperate key switch. As luck would have it I picked up a 78 Johnson w/out controls but it came with the remote control box and the engine end of the wire harness.
The wiring under the helm has been completely gutted prior to me buying the boat, so I dont have much to work with. I have a Seloc manual for the engine am left scratching my head on a few things. The diagram in the book shows a 3 conductor plug connection going into the remote control box (I assume originally it was part of a harness coming from the helm, it supposedly has a purple, grey, and black wire. This plug connection and or harness from the helm is long gone on this boat.
1st. as per the manual- The purple wire in the non existent plug seems to route thru a horn then on to terminal A on the key, then somehwere on into the motor, WHERE DOES THE PURPLE WIRE ORIGINATE FROM?
2nd. as per the manual- The Grey wire in the non existent plug seems to turn into purple at some point in the harness and terminate in an unlabled strip in the diagram. WHERE DOES THE GREY WIRE ORIGINATE FROM, AND WHAT IS ITS PURPOSE?
3rd. as per the manual- The tan wire comming off of the motor ties into a horn, I have had the throttle shift controls appart and there is no horn in there, or anywhere else in the helm that I can find. WHAT DO I DO WITH THE TAN WIRE AND THE PURPLE WIRE MENTIONED ABOVE IF THERE IS NO HORN?
4th. Aside from the 3 red/green/blue trim wires coming out of the throttle/shift control there is a black 2 conductore wire hanging there, is this the neutral saftey wire?
Thanks in advance for any help on theese matters.
