If getting into this from scratch, be aware there are 2 power systems and the only thing they have in common is the starting battery. The first is power from the engine and it's wiring harness. Examples of "stuff" on that circuit would be the tach, an elec. choke if so equipped, hour meter, etc.
Then there's the boat power. It's used for lights, radio, etc.
A voltmeter, showing voltage available, needs to be wired to the master battery in a dual battery scenario.
Also, I run a dedicated ground to everything. I don't want power running through the boat's tubes or chassis components. Too easy to get corrosion going that can eat stuff up below the water line in a hurry. That's the school I was brought up in anyway.
