vnvet72
- Joined
- May 2, 2010
- 18
1986 90hp six. Still needing advice on the final adjustments for lean/rich settings. The SELOC manual I'm using describes in water adjusting via RPM's and in gear but the boat has NO tachometer which is another point of concern. So any recommendation for a tach. and wire connection will also be appreciated.
In my previous post, I stated that the boat sat for many years before I rebuilt the carbs but now, after the rebuilds the engine smokes BAD w whereas it didn't so much prior to rebuilding, it only ran rough. Now, it does run and idle much better but has not yet been in the water, only a flushing barrel.
ALSO, this boat has the Auto-Blend that one individual related it being a horror story. Owner has never had any problems in the past. Any other facts on that would be appreciated as well.
I am dumping the old red oil out (Johnson O/B oil) and putting Amsoil HP injector oil into it which is the same oil I use in my own boat w/225 Optimax. It's a clean runner. Although, I don't feel the oil is so much the main issue with the 90hp smoking bad.
Thanks for any help from those with the experience in 90/115Hp's w/ WMK39 carbs.
