I just got Michigan Wheel "Apollo" 14 1/8 x 19 for my 150 evinrude. I got it for 150 bucks(New). I put the hub in it and bolted it on the motor. When I spin the prop by hand I can see wobble in the area after the blades. The blades are straight, the core is straight all the way to the end of the blades. My question is this ok? Will this hurt performance? Will it hurt my lower unit? Does a brand new prop (Michigan Wheel) have wobble normally? I got it off EBAY. And lastly, no, my shaft is NOT bent. I have had 3 other props on it with no movement(in the last month).
