wobble rollers , need help
artysniper
I have a 1996 ez loader trailer with wobble rollers one fell off and i need to replace some more , so my question is,, my shaft size is 1 inch from top to bottom , side by side is 3/4 inch , (there oblong shaped) wobble rollers on there now are 5 inch by 3 inch i need to find the right one that will fit that shaft. i dont want to order the wrong ones.. can someone help .
artysniper
Re: wobble rollers , need help
thank you for quick reply . bearing lenght is 1 1\2 YATES 5" x 3" Molded Wobble Roller, (1-3/32" I.D. for 1" shaft) #500YW-8P
C.H. Yates part #500YW-8P
Durable molded "Yellow Color" PVC Wobble Roller will not mark boat hull like standard black rubber rollers.
Diameter - 5"
Width - 3"
Shaft Bushing I.D. - 1-3/32"
Bearing Length - 1-1/2"
For use with 1" shaft will this one fit thanks again .
