OptsyEagle
- Joined
- Sep 13, 2006
- 1,359
I have a question about this procedure:
Magneto Armature Plate)
(J. Reeves)
If the armature plate has a a loose fitting, wobbling motion (the plate that the points, coils etc are attached to), it is usually caused by a slightly worn support ring. This allows the point setting to change erratically as the armature plate turns.
The cure is to remove the armature plate so that the support which is attached to the powerhead with 4 screws is visible. Then, with a screwdriver and hammer, or some tool of your choosing, and looking straight down at the support ring, make an indentation at what would be called the 12, 3, 6, and 9 O'clock positions. Install the armature plate and check for a smooth turning wobble free movement.
You may need to do that procedure a few times to obtain the proper fit (not too tight, not too loose), but it's worth the effort.
When I remove the armature plate and then remove the plastic bearing ring, I am not sure if I am supposed to put the indents on the level of the support ring where the 4 screws are or in the edge area where the plastic bearing ring goes (slightly elevated and eventually covered by the plastic bearing ring). The other alternative is the 2 inch diameter metal material that surrounds the armature cam that also looks like it supports the armature plate in he center, as well.
The area where the 4 screws are, on the support plate, seems too low and it doesn't seem to me that it actually touches the armature plate and I am not sure 4 indents would do anything there. Perhaps I am missing something with this procedure. I don't want to bang an indent in the wrong area. Appreciate some help
(J. Reeves)
