wont idle and only has 30%of power wide open
brickboy 2000
1 have a 1984 mercury 50 hp ,it wont idle unless throttle is fully open ,and when your running it only goes about 6 mph. last year it ran similar and the switch box was replaced 307$ .i didnt winterize it ,took it out yesterday and it is running terrible,only on 2 cylinders,any idea how ican fix this problem.
thank you
kennyboater
Re: wont idle and only has 30%of power wide open
sounds like a fuel problem. to start, make sure you have fresh gas. and clean lines. if that does not fix it and because it was not properly stored for winter, get a manual and clean/rebuild carbs
CharlieB
Always test spark, Basic troubleshooting, check compression, check spark to prove that the mechanics and electrics are good, then move on to the fuel system.
brickboy 2000
only firing on 2 cylinder checked all the coils there all good,cdi box brand new also,could it be the trigger,
thanks
