shotgundexter
- Joined
- May 24, 2010
- 24
Engine will not idle, it will stay running if i continue to pump throttle. It will stay running at about 2000 rpm but if i try to idle back just a hair--rpms will drop and engine dies in about 3 seconds. It will rpm up normally, and seems fine untill i leave throttle alone.
-- i have replaced the intake exhaust manifold gasket, drained fuel added new fuel, cycled fuel through a water seperator and seperate fuel filter.
---installed new fuel filter in between tank and fuel pump- cheap inline style, took out fuel filter that is in the carburator- cleaned and reinstalled.
----changed spark plugs, the existing plug wires are 2 years old
---took out fuel line and filter sprayed with carb cleaner, removed air jet idle screw and sprayed carb cleaner in there, then cleaned the screw with carb cleaner --put all back together.
-- i have tried keeping it running for a few minutes to get up to temp, brought rpm up some but still will not come down to an idle--it comes down to die.
--is there any possibilities other than carb rebuild?
