wont reach top speed
mtsontakis87
i took my boat out today which has a 5.0 v8 and it wouldnt reach its top speed which is about 35 mph...it was only running 20mph tops....i dont know what could have gone wrong it was running fine just yesterday .... would putting in bad gas cause this ...cause i heard about bad gas being pumped at the marina where i get my gas from latley.... maybe spark plugs carburator ...please help !!!!!!!
thank you
HT32BSX115
Re: wont reach top speed
thank you
Howdy,
Welcome aboard!
You should probably start with a little reading!
The following link will have a LOT info in it.... MUST HAVE Technical Information for DIYers.
Read #1 and #13 first....
Regards,
Rick
http://forums.iboats.com/showthread.php?t=342393
mtsontakis87
yea i already checked that out ...but based on the amount of throttle im giving it the rpm where they are supposed to be but the boat just isnt moving as fast as it should be... any other suggestions ..idea???
cr2k
If your RPMs are up where they should be you have 2 areas that can be at issue, prop hub and engine coupler.
