Fiveo Invader
- Joined
- Mar 28, 2008
- 38
Has anyone had the problem where the boat wont shift into neutral when the motor is running? 1989 Mercruiser 4.3 with an Alpha 1 outdrive.
When the boat is idiling, it runs like a dream. When I try to go to neutral it will go directly into reverse. I know the damage that will be caused by this, and ended the season early last year because of it. Now that its going to be Striper season here in NJ in 2 months, its about the time to fix it.
I can put it in neutral when it is off and then start it fine. The shifter is original and the linkages are all straight. The connection in the outdrive is fine, as I had the drive off a couple times last year. (the boat was not in great shape when i got it).
Any info would be awesome. Is it a new shifter that I need? Please dont tell me that the outdrive needs to come off again.
Thanks in advance.
Thanks in advance.
