briancollins1
- Joined
- Aug 22, 2016
- 14
Alright everyone, I've tried to wrap my head around what is going on but just cant so i figured i would come here to see if anyone had any input. I put the boat in the lake today a 1997 sea ray 210 signature series with a 5.7 tbi motor and an alpha one gen two outdrive currently an SEI outdrive. I am in the middle of reproping the previous owner had a 5 blade prop we moved to a 3 blade alum 14 1/4 X 21 recommended by sea ray. Off the dock nothing different everything went as planned, stopped after a couple of minutes of idle and realized we forgot the tube. Went back and when going to dock noticed the boat wouldn't go from fwd to reverse when docking. So the trouble began. When the boat was running we had to yank it to get it to reverse and when in reverse yank it to forward. As i started trouble shooting i readjusted the cables with the boat off put in forward to check engagement and vise versa in reverse. The problem only exists when the boat is running. The more i messed with it I couldn't get the boat to go forward in only would go in reverse and when the shift lever was pushed hard into forward it would only rev as if i was full reverse. The boat also would not catch neutral but when it did it was hard. I do know my safety neutral switch needs adjusting but jumped it for the trouble shooting. I am at a loss because everything works perfect when the boat is off and all cables move freely when checking adjustment and nothing seems to be "off" that i can tell at all. If anyone has any insight to this please let me know as it is greatly appreciated. Thank you in advanced.
