AGENT 37
- Joined
- Mar 2, 2007
- 319
My F100 is starting to do this..... it's running so well that it doesn't want to stop. I turn off the key and it keeps on running without a miss, I pull the kill switch and it continues to run. If I rev the motor up a little in neutral and drop the throttle back down it might shut off. I tried bumping the trim switch when it did it the other day and it shut down, today the trim switch didn't kill it. The "key on" power to my other instruments turns off with the key. I also have an erratic tach. The volt meter reads a constant 14 volts with the engine running though. I am suspecting a main power relay.... any other suggestions?
