hello,i have a 1978,2 stroke 35hp selva ,it has spark on the plugs and fuel going to the carb,but it seems no fuel going to the plugs ,can you help,,thanks piperdog
Carefully squirt fuel mix into the carb intake if the motor responds you most likely need to rebuild the carb with careful attention to cleaning all passages and jets.If the motor has sat a lot you should go through the fuel syatem from tank to carb.
