Won't start after Winterization
BronxBomber2
Engine:
Volvo Penta 5.0GL-F
3869308
4012176482
I am a first time boat owner and have only owned my boat since last summer. It ran great last summer, but after trying to awaken it from winterization it will not start. I pulled the fuel filter and there is no fuel in filter. I'm not even sure where to begin diagnosing my problem. I can find shop manuals for 5.0 GL (A-E). I see no mention of F.
Ayuh,..... Welcome Aboard,...... Is the gas in the tank,..?? How much,..?? was it stabilized last year,..??
If you pre-fill the fuel filter, 'n run another piece of fuel hose to a gas can near it, the fuel pump should pickup the gas, 'n it should Start,.....
You can diagnose from there,.....
BronxBomber2
The gas tank was filled prior to winter and stabilized. I will pre fill the filter and run to a gas can and see what happens. Thanks in advance for your help!
89retta
What dodge said and what part of the country do you live
BronxBomber2
It was winterized by a local Marina. I live in Pennsylvania. So I filled the filter with fuel and then pulled and put back in fuses and relays associated with the fuel system to see if I saw any damage. I decided to give it a shot at starting before i pulled the fuel line to try fueling from a portable gas tank. Shockingly, it instantly started. Not sure what the problem was but I hope it doesn't come back... Thanks!
