Paul eagen
- Joined
- Jun 15, 2009
- 71
Ok here we go, 79 Thompson 2.5L GM engine when I turn the key some thing is clicking. cant tell if it is the starter solenoid or the slave solenoid. but the motor will turn a little bit. Battery is at 11.7v when not in use. Had starter check at a shop they said it was good. checked alternator output while running it is 15v . battery voltage when running is 12.6v. checked resistance of wires from bat to ground, bat to starter, starter to slave sol. ,and slave sol. to ignition switch all less than .5 OHMS. If I put the battery charger on it it will start .I cant see why the starter wont turn the motor over with out the battery charger. Any help would be greatly appreciated. Oh the battery is only one year old.
