88 Yamaha 200hp. When I try to start or raise / lower trim there is only a temporary clicking coming from the relay assembly. This is the point of where the main wires from the boat connect under the cowell. <br /><br />Took the cover off this 2" x 3" box (which on Yamaha's parts diagram is called a "relay assy") and there are no fuses only connections. When I have someone turn it over or try to move the trim this box sounds like it is shorting out and it vibrates slightly. Do I need to replace or could it be something else?
