Re: Won't start when hot
OK Just bringing Things up to date. 'Bout 70 degrees today 9AM boat starts right up warm up to temp 150 run at idell 5min. boat is in water. So cooling is fine. We know it's getting gas 89 octane in tank, fresh. Turn off key,let heat build 5mins. Boat will not start. Now we have new fuel pump, gas lines are fine. carb getting gas. When we push throdlle gas is entering carb, We have even dripped gas into carb. So we beleive carb is getting gas into the barrels. On the Electric side we used spark tester to see if spark is stronge. Doesn't seem to be a good strong spark. We have tested to see 12v from key to distributor, from dis. to coil(tryed a new coil, no difference). New module( still no difference) New cap and rotor(as I said previous It needed new cap and rotor) So now again,When It's cool say in the morning This boat runs like never before. Just don't shut it off. Sometimes it will start but more then likely it wont. Yesterday I let it sit after not starting 6hrs. still wouldn't start. But the next morning it started right up. Tryed cooling down the Dist. coil Volvo Penta#3854001 Started twice after doing so ,Third time would not. For $45bucks I'll try a new one. Little work but it may do the trick....Any thoughts?????
