wont start
dominic_olenick
i have a 470 merccruiser that wont start unless u put jumper wire from battery to + side of coil points distributer and it tries to start if u keep turning the engine over with the key but as soon as u let off it will die any suggestions
fishinpa
Re: wont start
so is that 2 statements in your long sentence ??
does it run when you hot wire it ? ie : with the battery to coil wire added
and does it try to run without the jumper when you hold the key in the start or (cranking ) position ?
just trying to understand your statement here .........
for all of us lol
fish
Rscardina
Re: wont start
that is one awful sentence...but more about punctuation later..! hahaha
So, you jump to the starter coil and she fires? Does she stay running after you remove the jumper?
With the key, she seems to want to fire? or does fire and then sputters out?
Please explain this a bit more as suggested.
Off the top of my head it sounds like a you don't have enough votage from the key to pull the coil in. Possible some corroded wire or just plain dirty..
Hard to say without some more information.
dominic_olenick
Re: wont start
sorry about the first post was in a hurry
the motor will run with the jumper from the battery to the coil and if u take it off it will die
when u turn the key on and try to start the motor without the jumper the motor tries to start but when u let off of the key it will die and if u keep on cranking the motor it will try to run
frank246
Re: wont start
You should measure ~10 v at the coil when the ign. key in the run position.
Did you check the landyard safety (kill) switch ?
Good luck!
dominic_olenick
Re: wont start
thanks for all the help on here i found the problem bad connection on the bulk connector fixed it and it started right up
