wont start
14dar
I have Johnson 35hp 3cyl I just had it rebuilt put all external parts back on all part work when I took it apart now it will turn over and wants to start but won't any ideal anybody
itsaboattime
Re: wont start
What is the model number? What year?
Pull the plugs. Are they wet? Is your timing correct? If you squirt a little pre-mix in the carb, will it start?
14dar
Re: wont start
It's a 2000 j35tel3ssb it has plenty of spark plugs are wet how u go about timing it yes it will run for a little bet
boobie
Re: wont start
Did you remove the oil tank and mixer on it and bypass it ?? If you didn't, do it !!
boobie
Re: wont start
Check the spark with an open air gap spark tester set at 7/16".
Bosunsmate
Re: wont start
Check your primer solenoid isnt flooding it out or that your carbs arent flooding.
Do that by checking your primer bulb holds firm with engine off
Re: wont start
Orange / blue is on the top coil ?
14dar
Re: wont start
Ok question on the timing the flywheel set on a key only one way to do it so how do u set the timing I'll throw this at u this motor was a 25hp and I made it a 35hp change jets in carb would this make a different in carb setting and timing
Re: wont start
????????------The 35 HP model has bigger pistons and more displacement.----What else was done to this 25 HP motor ?---Timing generally does not need adjustment on these motors.
Bosunsmate
Re: wont start
Yes Just the key sets timing. I always check it as if the key breaks or the powerpack starts failing timing can go out.
Bosunsmate
Re: wont start
Well if it wasnt doing it beforehand id say your jets are too big
boobie
Re: wont start
What exactly did you do to make it a 35 HP ??
14dar
Re: wont start
Ok had sleeves bord out to 35 spec new piston change jets in carbs to a 35 hp only this was done that's all there is to make it a 35 hp
