I need some help here, I have a 96 johnson 50hp remote start motor. Yesterday went out ducking and it was very hard to start. I had the motor up in the tilt position for about 2 weeks. I thought maybe the float stuck or something. Ended up squirting a little gas/mix straight into carbs. Finally fired up after a few minutes. Ran great all the way out. Then I had to tilt the motor up after we got to where we were going. It sat for about 5-6 hours and would not start back up.
Cranked till batt was dead. Ended up having to be towed back in. Looked at it today and took plugs out and turned flywheel manually. Had spark on bottom plug but not top. Both plugs are good, and both wires are good. Any ideas??<br /><br />Thanks in advance
