Just got home from the lake and havn't had much time to look over my motor, but was wondering if anyone had an idea where to start. Went out for the day and all was running smooth, then all of a sudden I heard a sound that wasn't right. I am still not sure what the sound was, I just knew I wanted to slow down and listen to it. As I slowed the engine died and wouldn't start again. The starter would engage but was not turning the flywheel. I thought maybe the battery so I hooked up my spare and same thing. I pulled each plug and looked at them. This is a 1973 135hp Rude Model # 135383M if looking at the motor both plugs on the port side seemed pretty dry. both plugs on starboard side looked about right(not dry, but not drenched) Then just to make sure I pulled all plugs and turned her over (I was thinking this tells me that no piston has seized up?) Here is what I was thinking...plugs dry...no gas (are the top 2 plugs served by the top carb or is it possible the port 2 are seved by one carb? the later would be easier to understand) then I am brought to the why it won't turn over problem...I was thinking it could be the starter, but that wouldn't have made it die while running. I believe the second battery proved it wasn't a battery issue. So maybe a short to ground drawing juice from starter? not sure how this happens mid run <br /><br /> Bottom line...am I missing something else that would cause these symptoms before I start tearing into things? Still a rookie in the engine compartment, but loving the learning. I would just really like to learn it before next weekend! Thanks for any input!
