My project involves replacing the wood transom in a aluminum boat . I have the transom built and ready to install,except the finish. I want to be able to see the wood after the finish is applied so only a clear finish is acceptable. In the forums i have read that most use a epoxy coating ,then for UV protection coat that with spar varnish. West systems recommends coating there epoxy this way. My question is why use the epoxy ? Why not just coat it with the varnish? thanks for any advice in advance
